Thanks to the members discussing dual quad identification ..
https://www.forums.ncrs.org/showthre...80381&uid=5856
Here's the mystery.
Car/motor unrestored but obviously has had work done. Just passed 40,000 miles last week enroute home from show.
Block stamped F1223CT (I read as a dual carb block)
Dual Carbs..no tags but bodies both show 0-049 with 6-1299 horns (from carb ident discussion these apparently would be for 270HP)
Distributor has vacuum pot on lower right side but hose leads nowhere.
No apparent place to put empty end of hose on carbs. Guessing the dist has been replaced with incorrect unit.
Intake manifold is 3739653
Tach in car is low RPM running from generator.
I thought this car was a 245HP.
What's wrong with this picture and what am I missing?
Here's the mystery.
