Do either the 63-4 or 1965 judging guides call out the vertical striations (?) on the original #3828373 caps? The repops I've seen (2 different sources?) obviously have had those "stretch marks" sanded/ground away before chroming. Or is this another situation where the repop is now being viewed as the original?
63-5 Oil filler cap
Re: 63-5 Oil filler cap
Hey Loren, agree on the 'stretch marks' on sides but have a question on the 'dimple' on some of the caps in the middle of the top. Was that an early 63 item?
Dan1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Loren, Dan -- in 5th ed. '65 TIM&JG, no mention of striations (nor dimple on top). On my '65 L76 cap, the stretch marks / clamping marks -- vertical lines) appear on both long sides between the four ears. No top dimple.- Top
All------
I think the "stretch marks" and "striations" are symptomatic of worn tooling. In 1963, the tooling for these caps was new. As time went on, it wore and less-than-perfect parts were made, but still 100% functional. So, why change or refurbish it?
With the number of these caps being manufactured at the time, I'm sure that some tooling wore out completely and was replaced. So, there are probably original caps used on later model C2 (and 1968) that didn't evidence tooling wear. I expect it was just the "luck of the draw".
Current reproductions might be manufactured from new tooling or, possibly, refurbished original tooling.In Appreciation of John Hinckley- Top
Bill, Your cap appears to be an over the counter service replacement. Configuration is not typical either. I have owned a ton of those over the years.
It appears a certain repro chrome cap I saw recently was patterned after your grayish one as it is not correct.
The verticle lines at the 4 corners is what I look for. The dimple on some of the originals is like Jorjorian said.
Go ahead andTry and get a chrome plater that will not remove the dimple and verticle lines. Seems to be impossible. I just had 7 chrome plated and they are all ruined. This in spite of all kind of notes on the caps.- Top
Here is the 63 (left) and 64 (right) Both have the same smooth round area on top even though the 64 is hard to see (poor photo)- Top
Excellent pictures Alan, the later ones have a very gradual hump as it tapers to the cap's edge.......not the half circle look.- Top
Dan, that "dimple" is when you tried to hit it on with a hammer........SOP on a "Bubba" resto......- Top
