The headlights go up and down correctly. The passenger side is slow and it like the vacuum switch.
Could a bad switch result in a vacuum leak and cause a rough idle and acceleration?
The vacuum port on the carb is now blocked off and the car runs excellent. When I hook the vacuum line back up the problem returns.
I have followed the good Dr's vacuum line install diagram and it looks like it is correct.
Thanks, Bill
Thanks, Bill
