My 67 4-speed speedo needle bounces +/-15 mph at all speeds as I go down the road. It used to do this only occasionally at lower speeds. Now it does it at all speeds all the time. It is extremely annoying. It appears to be the original cable (nuts have correct AC markings). My guess is that the rotating cable is getting hung up as it goes through its rotation likely at bend points. Would a repair for this condition be as simple as removing the cable and injecting oil down the outer sheath for lubrication or will this require a new cable? I don't want to remove it twice.
Dereck
Dereck
