Re: Radiator Shroud Extension
BELIEVE the red zone band on your temp gauge! That's why designers put it where it is. If your temp system is accurate, then you're 'safe' when you're hot but still below the red zone...
You'll note as the Shark era progressed and more emission control features were added, the red zone climbed upward (260F, Etc.). That's because underhood temps increased in lock-step.
Look at where the danger zone is on your current daily driver. You might be surprised to see it pushing 300F. The inherent 'fear' of running too hot, is something that's 'normal' among those new to the care and feeding of these classic cars.
They tend to be 'gun shy' of anything that's above 160-180F and lack the actual driving experience with the profile these cars had when they were factory fresh/new. They know the engine's been overhauled and they're on a hair trigger to seeing the temp gauge climb above it's 'normal' range.
Today, we have MUCH more accurate temperature reporting systems on board + engines are designed with a myraid of compensating systems such as automatically switched electric aux fans. So, our daily drivers don't exhibit as much coolant temp variance as the old/classic cars did. But, that's the nature of the beast!
Bottom line, if you're in grid lock/stop-go traffic on a hot day and you see your temp gauge rising, you CAN compensate! Manually do what the TCS/CEC system did and simply put a little 'foot' on the gas to boost engine RPM and pull more air through the radiator. You don't have to sit and wait to see if she's really going to boil over with a geyser of underhood coolant!
