Re: 1970 LT-1 Valve Lash, Idle and Idle Mixture Setting
You didn't mention your old lash before, unless you edited it out. Did the valve train clatter before you set the lash? It should have, and if it didn't then you have a hydraulic cam installed.
You need to measure lobe lift, which is .3057/.3234. Unfortunately, even if you manage to get those measurements accurately, which won't happen unless your dial indicator's axis is exactly parallel with the pushrod axis, the result is inconclusive in itself.
Just for fun, set them as if they were hydraulics and see how it idles.
