Greetings!
I am having a problem with my 59's driver side brake light. (The passinger side works perfect) Here are the particulars:
Tail light works fine when head light switch is on.
When the brake pedal is depressed, the brake light does not light up.
I took out the passinger side light core and hooked it up to the driver side and it did the same thing, no brake light.
I changed bulbs....still no brake light.
Do I need to install a new plug? The harness is about 4 years old.
Do I need a new brake switch at the pedal?
Thanks to any help in advance!
Tim Allen
46673
Tim Allen
46673
