Im confused about date codes on my 59 - NCRS Discussion Boards
  • David H.
    Infrequent User
    • March 1, 1982
    • 7
    Is it possible to have the engine cast date code 3 days before build date of the car
    DFH
  • David L.
    • December 1, 1981
    • 116
    Re: Im confused about date codes on my 59
    Question ...What's stamped on the pad as the build date?
    David
    • David H.
      Infrequent User
      • March 1, 1982
      • 7
      I don't have access to it right now. but if was cast in april 59 would it go in a car assembled in april
      DFH
      • Tom B.
        • March 1, 1978
        • 720
        That's pretty tight but I do believe that it is possible. There are stories of the machining being done on blocks that were still warm.
        Tom
        • David H.
          Infrequent User
          • March 1, 1982
          • 7
          Thanks I thought it was too tight
          DFH
          • James G.
            • May 31, 1976
            • 1556
            Safe is 2 weeks prior to car assembly. I have engines assembled the same day as the cast date however.
            So car assble, March 19, engine assemble, March 5, cast date genearlly one week, or Feb 27. But can be closer to assembly date.
              Remotely possible, but unlikely. What's the block casting date, the pad stamp on the block, and the VIN of the car?
              • David H.
                Infrequent User
                • March 1, 1982
                • 7
                Cast date april 13, assembly date april 14 I was wrong on the build date of the car according to the birthday calc. on the C1 registry it was built on april 20.
                Thanks for all your help.
                DFH
