I have rebuilt my steering box for my 1965 following Gary Ramadei's and Duke's articles/papers. I am at the point of setting the worm shaft and sector shaft preload. Duke refers to "notchy" feeling of the bearings - this seems like an understatement. When I use my 0-30 in/lb torque wrench on the worm shaft and rotate it the readings jump between 0 and 5 inch lbs through the rotation. After setting the worm shaft preload as best as I can, I attempt to set the sector preload and the total varies through a rotation or more between 5 and 14 in/lbs. There seems to be a lot of variation of the readings through the rotation as a result of the "notchy" feeling bearings. I am trying to film it and post a video on you tube - it is very difficult to explain. I used a corvette steering rebuild kit with under size bushings to achieve 1 thou side play on the sector shaft and ground the adjuster shims to achieve a 1 thou clearence. When the ball screw and worm were outside the box and asssembled it rotated very smoothly.
Any thoughts?
Dave
Any thoughts?
Dave
