1967 Corvette SB, AC Fan/ Fan Clutch - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi Guys,
    I'm looking for detailed info and pictures of original 1967 Corvette small block, air conditioning fan and fan clutch.
    Dave
  • Scott S.
    • March 1, 1979
    • 747
    Re: 1967 Corvette SB, AC Fan/ Fan Clutch
    There are some great c-60 pictures in Nolan Adams vol II
    Scott
      Originally posted by David Schutzbank (50698)
      Hi Guys,
      Dave
      Dave -
      Here's one; fan clutch is the same as non-A/C.
      • Jack H.
        • April 1, 1990
        • 9906
        John's right, no difference in fan clutch based on A/C option for your year. Plus, as the JG book states, there were two active fan clutch suppliers (Eaton and Schwitzer) that were used on a rather random basis at the factory. The only difference was SB vs. BB and that dictated the shaft length of the fan clutch.
        So, there's no 'correct' fan clutch for your car. It need to have the right shaft length based on SB vs. BB and can be EITHER an Eaton coil unit or a Schwitzer bar device.
        • David L.
          • July 31, 1980
          • 3310
          The 66-67 Corvettes 327 w/AC were issued two different 18" 5-blade fans on the assembly line.
          1. GM # 3789562 made by Hayes-Albion (stamped "H", "FRONT", and "W" on the back side) with 4 rivets/blade on arrowhead shaped attaching arms.
          2. GM # 3863137 made by Schwitzer (stamped "912239", the Schwitzer part number, and a date code on the blades). The picture in John's post #3 is of the Schwitzer fan.
