1960 7320 ? - NCRS Discussion Boards
1960 7320 ?
  • Don H.
    • December 1, 1981
    • 1482
    1960 7320 ?
    Two questions for a 1960 7017320 FI unit. !. What do you recommend to seal the brass "T" into the main control diaphram cover? 2. The two thermostat housing pictures attached show: Housing A is larger font so is 59 - mid 60. Housing B is smaller font so it is late 60. Is this correct? Thanks for the help. Don H.
  • Bill M.
    • April 1, 1977
    • 1386
    Re: 1960 7320 ?
    My '59 has the larger font.
    • Don H.
      • December 1, 1981
      • 1482
      Re: 1960 7320 ?
      Thanks for the reply Bill. I ended up using teflon tape on the fitting in the main control diaphram cover. I drove it about 100 miles today to a show & seems to be fine. Don H.
      • Jim L.
        • September 30, 1979
        • 1805
        Re: 1960 7320 ?
        What do you recommend to seal the brass "T" into the main control diaphram cover?.
        Don,
        I recommend against Teflon tape, period. It shreds and always seems to get into places it doesn't belong.
        Either screw the "T" fitting into the diaphragm cover dry or, if you feel some sealant is absolutely necessary, use a small amount of Teflon paste.
        Jim
        • Don G.
          • March 1, 1989
          • 251
          Re: 1960 7320 ?
          My '61 unit has the larger font and the numbers are sharp and fully formed. However, I do not know the history of this unit. It has been in storage for a long time and looks original but you never know for sure.
