I have a 1964 L76 and the water pump went out. Ater removing it I decided to check the pulleys and balancer to make sure they were correct. The balancer is not the 1 3/4' original but is a 1 5/8' after market replacement w/o the reinforcing fins, so I'd like to replace it with the original type.
I have a few questions I'm hoping someone can help with.
1. the balancer installed does not appear to have any mounting bolt, so I assume I just need to remove it with a puller, is that correct?
2. At this point, I don't see any threads in the end of the crank and I believe the correct balancer uses a hex bolt to attach to the crank. Does this mean the crank has been replaced at some point and I no longer have the correct L76 crank?
3. If I no longer have the correct crank that will accept a mounting bolt for the new original style balancer, can I still install the original style balancer by just pressing it onto the crank? If so, can this be done with the engine still in the car?
