Another Holley whistle - NCRS Discussion Boards
  • Robert S.
    • December 11, 2008
    • 122
    Car is a 71 LT-1. The whistle just developed and is intermittent, and seems most noticable during conditions of high manifold vacuum.
    It appears that the whistle is coming from the primary air horn (cupping my hand above the choke without blocking air muffles the sound).
    I would think the whistle would be external to the carb if a leak at the carb base gasket or throttle shaft. Any ideas on this one?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Another Holley whistle
    does the carb to manifold gasket match the manifold opening ???
    • Robert S.
      • December 11, 2008
      • 122
      Clem, the gasket is correct.
      • Ronald L.
        • October 18, 2009
        • 3248
        Throttle shafts - search this forum, lots on this and I just got rid of my whistle today, among other problems by replacing the old carb with the restored original. Also there is a good set of video's on how to adjust the Holley's on u-tube but can't beat the advice here!
        • Robert S.
          • December 11, 2008
          • 122
          Ronald, my carb is a restored original. It does not have many miles on it since installed and just started the whistle today. I made no changes or adjustments prior.
          Was your whistle noise coming from inside the primary air horn?
          • Ralph S.
            • February 1, 1985
            • 935
            Hold your finger over the primary vent tube while the car is idling, if the engine stalls i have found the power valve diaphram is leaking and needs to be replaced. The whistle is coming from the vent tube.
            • Robert S.
              • December 11, 2008
              • 122
              Thanks, Ralph. I did try plugging the primary vent tube with my finger as you mentioned, and it made no difference in the whistle (no change in the idle either).
              • Ronald L.
                • October 18, 2009
                • 3248
                Yes, Noise was isolated with a hose.
                If the power valve is blow, easy to do with one backfire, on Holley's prior to 1992, you can turn both adjusting screws in closed and the engine will not die. Check that, is it running rich?
                Here is one link...http://www.bob2000.com/carb.htm
                • Robert S.
                  • December 11, 2008
                  • 122
                  Ronald, power valve is not blown. Idle mixture screws will stall enigne when turned in.
                  Engine runs and idles without problems.
                  • Ronald L.
                    • October 18, 2009
                    • 3248
                    Need to talk to whom ever did the restoration relative to bushing the throttle shaft. Did bush it due to wear?
                    • Robert S.
                      • December 11, 2008
                      • 122
                      I do not know the details of the rebuild. I'll probably pull the carb and look at the throttle shaft since it seems to be the most likely cause based on your comments.
                      • Robert S.
                        • December 11, 2008
                        • 122
                        I wanted to follow up and let everyone know that I THINK I found the problem. I pulled the carb off this morning and I noticed that the large screws on the bottom that attach the throttle plate to the main body were somewhat loose. I did not see any other problems, so I snugged those up and reinstalled the carb.
                        I then went and drove the car quite a bit and have not yet heard the whistle.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          i would cross that carb rebuilder off of your list.
                          • Gerard F.
                            • June 30, 2004
                            • 3803
                            I agree Clem,
                            If one of those screws fell into the intake manifold on one of those full open intakes, it would have really raised havoc. The restorer should have used some Loctite.
                            Jerry Fuccillo
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              Originally posted by Gerard Fuccillo (42179)
                              I agree Clem,
                              i believe that is why GM holley carbs do not have the center 2 baseplate screws like the holley factory carb do because they can fall into the intake if they get loose
