Did GM originally balance the flywheel and pressure plate as one unit? If so, I would assume the drilled holes in the back of the flywheel would be 180 degrees out from the welded weighted plates on the front (transmission side) of the pressure plate. I lost painted the factory markings on both the flywheel and pressure plate.
I am reassembling now- let me know if this is wrong to assume.
Jeff
Jeff
GM put the "X" there if you just replaced the clutch disk and reused the pressure plate
