Coil Spring Issue on a 1963 - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1273
    My left front coil is tilted in the "cavity" and it rubs against the frame. I can see a twisted rubber donut in the upper "A" frame.
    I'd like to attempt to compress the spring and see if I can move it back into position. In addition, I will ry to remove the donut
    Which spring compressor will work better, the internal or the external? Your experiences will be helpful.
    Jerry
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: Coil Spring Issue on a 1963
    Gerald,
    It is good to remove the rubber spacer from the frame pocket as it is the source of your spring malalignment problem. Is there one on the other front coil as well? You should remove both sides if so.
    These spacers were typically installed by dealers for customers who complained of low ride height of their new 63's. GM went to a stiffer spring in 64.
    I've never used an internal coil spring compresser and I don't think an external compresser will work very well. I just remove the shock and use heavy duty all thread. There was a Restorer article written about a year ago by Rob M (?) detailing the proceedure on a C1, but it also works for later model cars.
    be careful..
    tc
      Jerry
      Jerry------
      It's virtually impossible to use an external-type coil spring compressor on a C2 or C3 Corvette. You must use an internal type compressor.
      I think you will have to remove the spring to remove the spacer, then re-install the spring (or, use new springs). If your ride height was right, if you remove the spacers and go back with the same springs, the car is going to be lower in the front.
      • Gerald C.
        • June 30, 1987
        • 1273
        Thanks for the feedback. I'm going to use the threaded stock avenue. I did this years ago and in fact, wrote an article for the Restorer Magazine. But that was used when the body was off of the car.
        I'm taking the approach whereby, I'll use the threaded stock, etc. and remove the lower A frame bolts. Then try to straihten the spring out after I release it.
        Jerry
        • Loren L.
          • April 30, 1976
          • 4104
          If you really want the truth, the car has sent all the signals that it is now TIME to have a good front suspension shop/man determine whether or not 47 years =s "Do The Whole Front End".
          • Gerald C.
            • June 30, 1987
            • 1273
            Loren,
            I agree. I'm trying this now and will bring the car to a front end shop in the springtime.
