Tire tub repair - 66 - NCRS Discussion Boards
  • Kenneth A.
    • February 1, 2006
    • 64
    I pulled the tire tub off of my 66 to get to and noticed the lip was cracked on the tub itself = not being a fiberglass expert - is there a way to make the repair and get the original black molded look??
  • Patrick N.
    • March 10, 2008
    • 951
    Re: Tire tub repair - 66
    Ken,
    I will have to look it up but there was a good article in the Restorer (maybe in 08 or 09 issues) on how to repair the lip of the tire tub.
    Essentially you would make a mold of a good section of your tub and then transfer the mold to the damaged area. Using fiberglass strands and tinting the resin black ( i think that was part of the process) you make the repair using the new mold as your form. I am skipping many steps but you get the idea. The result in the article was impressive.
    I will look tonight; maybe someone can point you in the right direction sooner though.
    Pat
    • Jeff C.
      • 40
      Scott Sinclair from Canada has a very good process to make the repairs. He is in the Driveline under services. He has a heater box of mine and also does stud repair work. Very knowledgable guy and great to work with... Jeff
      • Larry M.
        • January 1, 1992
        • 2688
        Agree.
        Scott did my 1967 tub a few years back and did an excellent job. Highly recommended.
        Larry
        EDIT: I believe that Scott also wrote the Restorer Article that Pat mentioned above.
        • Patrick N.
          • March 10, 2008
          • 951
          I found the article if you are interested in looking in a back issue and tackling the job yourself,
          Restorer Summer 09, Vol 36, Num 1.
          Dave Kitch and Barry Holmes did a great job documenting the process.
          Pat
          • Kenneth A.
            • February 1, 2006
            • 64
            Thanks for all of the help - I am going to try to go it alone based on the articles - I will take some before and after pictures and we will see.
            • Randy R.
              • March 1, 1983
              • 477
              I found black resin at Corvette Image. They are located in Oregon.
              Randy
              • Scott S.
                • March 1, 1979
                • 747
                Best of luck, If you still need help and technical advice please call me.
                Scott
                905-857-1463
