Has anyone tried this rivet tool? I just noticed it recently, advertised in the July-August Driveline, and didn't find anything about it in the archives.
Has anyone tried the Aero-Rivet (Aero Rivet) tool, advertised in Driveline?
Re: Has anyone tried the Aero-Rivet (Aero Rivet) tool, advertised in Driveline?
Scott,
I had one machined just like it many years ago and use it on a regular basis with great results. I wondered how much they are charging for it.........Steven J.............- Top
I found a short write-up about the Aero-Rivet tool online from Corvette Fever Magazine (http://blogs.corvettefever.com/66232...ier/index.html), where they explained that it is "." (3/19/10)
One of the online vendors has it for $80.
It sounds like the tool you made is very similar. I'm in the middle of a body-off restoration, and I expect I'll be needing to set lots of rivets. Is a tool like this worthwhile, something that works in a lot of places? $80 seems like a lot for what it is, but having the right tool for the job can make a big difference.- Top
I purchased one so that I could rebuild my 68's heater box. It works well except it's too large to get in some of the smaller areas (corners) on the box. However, I was able to take a smaller C Clamp and drill a hole in one of the flat clamping surfaces and inserted one of the fittings (fitting that came with the Aero tool) that crimp the rivet. Overall a great tool, but it has limitations. With shipping it was around $84.00.
The one I purchased was not ratchet driven but was thread driven just like a C clamp so it's hard to get the same crimp each time.
Mark Franken- Top
Mark Franken
I don't know if they have a complete list like that, or a list broken down by model year, but if I was interested in selling a lot of these, I'd sure make one- Top
That tool is really only good on rebound straps. I made a ssmaller one that works on hadtopss and misc. items. Long Island corvette sells some rivet bucks that work pretty well. Also check companys that sell helicopter and airplane parts.They have loads of rivets in every shape and size and they are loads cheaper..............- Top
Forgot to mention. I use a crescent wrench to hold one end of the c clamp and than i use an air tool to ciinch it down, works in 2 seconds and usually comes out perfect...........- Top
