C3 temp sender BWD WT203 - NCRS Discussion Boards
  • Roger O.
    • September 7, 2009
    • 209
    The WT203 from Advanced and Orileys seems to be producing some good results. In boiling water the ohms reading is around 80 , prime would be 79.
    I've tested it in a couple cars with good results and have gotten positive feed back from several guys that have installed it in their cars.
    Most of the other high dollar senders are reading 50-60 degrees too cold.
    I took an original Delco sender and cut it apart and cleaned it up inside and put it back together , surprisingly it worked like it was new.
    Sure wish I had all the ones I threw away over the years.
