1972 LT-1 Engine Stamp Pad - NCRS Discussion Boards
  • Wolf S.
    • July 15, 2009
    • 94
    hi all,
    I've recently come across a 1972 LT-1 T-Top (build date May 9) with an engine stamp pad suffix CRT.
    In the 70-72 technical/judging manual(4th ed.) on page 55, it is written quote "Chevrolet servie records list CRT, CPH and CPJ codes, but Flint and Tonawanda report none were produced. Their existence is unverified."
    Any ideas? Is this a special engine?
    eat my dust
  • Kevin G.
    • February 1, 2005
    • 1074
    Re: 1972 LT-1 Engine Stamp Pad
    Wolf,
    This info does not answer your question but my LT-1 has a build date of May 10, 1972 and has a VO327CKY stamp. You might be onto something neat!
    • James G.
      • May 31, 1976
      • 1556
      vin 20854 was built around May 9, 1972 so your April 19 assembly date fits the mold. And yes, CRT is a valid LT-1 code, but with A.I.R Smog pump. The CKY was the same engine, but no smog A.I.R system. I will bet your car was sold new in California because of the smog pump system.
      • Kevin G.
        • February 1, 2005
        • 1074
        My CKY has the AIR.........?
        • James G.
          • May 31, 1976
          • 1556
          Al Colvin's "Chevy by the Numbers" says CKY has "NO" Air Induction Reactor smog pump system. Again, if the GM "UNION" assembled the car, anything is possible.
          • Kevin G.
            • February 1, 2005
            • 1074
            Mr. Colvin's information is apparently incorrect.
            • Michael W.
              • April 1, 1997
              • 4290
              I believe that all LT-1s had AIR irrespective of destination.
              • William H.
                • January 11, 2010
                • 65
                Clicky http://corvette-world.com/corvette_1...tion_codes.php
                • Wolf S.
                  • July 15, 2009
                  • 94
                  would be interesting to note how many on the board have a crt suffixed engine.
                  eat my dust
                  • Paul O.
                    • August 31, 1990
                    • 1716
                    Just to chime in all LT-1 no matter what state they were delivered to had the A.I.R. system installed. California cars may of had some additional or parts changes per there clean air requirements but the A.I.R. system already on board.
                    Paul 18046
                      • 15610
                      California had NOx tailpipe maximums beginning in 1971, but there was no NOx standard for 49-state cars until 1973.
                      AIR was a HC/CO control system, which had nothing to do with NOx.
                      Engines didn't require EGR to meet this early CA NOx standard until, but may have different spark advance map calibration. The LT-1 cam has enough overlap that it probably met the CA NOx standard without any additional work, but it would still probably have required a different engine code just for administrative/legal purposes.
                      • Mike G.
                        • July 31, 2002
                        • 709
                        my 72 lt1 is an april car and it is a cky. it also has AIR. i have never seen an lt-1 that did not have AIR. california car did have AIR and it has some other stuff as well. california car has a large metal plate under the carb. sticks out about 2" all the way around. also has two emissions lables.
                        • Mike G.
                          • July 31, 2002
                          • 709
                          did you buy this car yet?
                          • Billy O.
                            • March 1, 2006
                            • 18
                            Originally posted by Wolf Schuffner (50624)
                            hi all,
                            Wolf,
                            I've commented a few times on the CRT code (some of this should be in the archives). It would be interesting to see if your car came from CA. I believe mine did. I've seen no conclusive information on the CRT code with the research (minimal) I've done or the correspondence with Terry M. and Sal C. Let us know if you find anything out.
                            Billy
                              • 15573
                              There is a wide range between the VINs on those two cars. That is the most interesting feature to me. If there are two, there are lots more.
                              Something put on at Flint engine is different between the CRT and the CKY. The real challenge for all of us will be to figure out what that is. Flint didn't assign a different suffix code without some difference in the engine assemblies they shipped. You guys who own CRT engines might want to take the effort to find out where you car was originally delivered -- that might provide a clue to the why, but we still need to identify what drove the different suffix code.
                              For 1972 the base Corvette for California (CDH & CDJ) in addition to AIR equipment had a paper sticker affixed to the windshield stating compliance with California clean air regulations. Those engines had the brackets and exhaust manifolds compatible with AIR installed at Flint -- thus the different suffix codes. I haven't looked, but they may have received different distributors than 48 state base engines as well. Those are the kinds of features that brought about different suffix codes.
