Re: 1966 L36 Vacuum advance Mechanism
Duke, I know enough to be dangerous.
So the basics, yes, but I don't do 5000rpm on an original motor. 4000 is as high as we've had this one running and that's plenty fast, perhaps 100mph fast.
Yes within the accuracy of the measuring device on the motor we have about 8* initial at idle of 700rpm.
The mechanical is essentially all-in by 2000rpm and that kicks us up to 24*
Then for the third dimension, we plug in the vac advance and go on our merry way.
I can't set a surface, only key reference points that generally have a condition (RPM) tied to their value.
I am interested to learn more and perhaps set this up so it does liven things up, when hot, it still is pretty lame. I do have a new spring kit, w/o explication it seems one of the three springs are set up to not be fully advanced until you are way above 5000 rpm, the low end set looks to be all-in by 3000prm. It is a re-packaged Accel point & weight kit.
