1972 LT1 intake - NCRS Discussion Boards
1972 LT1 intake
  • Ron S.
    • May 10, 2010
    • 24
    1972 LT1 intake
    What are the correct bolts and washers for a 1972 LT1 aluminum intake manifold? Thanks Ron
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 1972 LT1 intake
    Ron there are no washers under any of the intake bolts. For a 72 there are a minimum of 3 differant bolts and one stud. The front 2 Drivers side are slightly longer and have a built in washer. The 2 bolts holding the ignition wire supports are different length. The other bolts are the same length and the stud holds the TCS solenoid Pass side. There are a few variation in head markings if you would go to the bottom of this page of your discussion there is a list of others who have asked a similar question. You will find many more answers in those lists. Hope this helps.
    Paul 18046
    • Ron S.
      • May 10, 2010
      • 24
      Re: 1972 LT1 intake
      Paul, Thanks for the info it was very helpful. Ron
