OK, I give up. I have spent the better part of the past two days trying to get my rear axle back in the frame with no luck.
Here is what I find.
Bolting the rear spring to the bracket in the front of the spring, the rear of the spring hits the top of the cross member in the rear. The shackle is suppose to go from inside to the outside with the nuts on the outside. That cant happen on mine because the shackle hits the frame. It will go in from outside to inside, but again, the bottom of the spring hits the top of the cross member. I've turned this thing every which way but loose and it just doesn't fit. I have checked and read all I can find on the subject, which doesn't seem to be much, and studied all my pictures. I have attached some pictures. I could use some suggestions.
