Re: Symptoms of Connecting Rod Failure
Clem;
My fuel pump spring failures were due to a porosity crack in a 305 block, circa late 1986. GM had a bunch of bad blocks that cracked completely down the valley from front to back. The mix of Antifreeze into the oil would some how bring about a chemical reaction on the fuel pump springs. Other symptoms were greasy like substance under oil cap and in pump cavity. I ran Mobil1 which led me to go through two pumps before it finally wiped out a cam bearing causing all kinds of valve clatter. One doesn't do too much troubleshooting when it's -10 degrees outside in an Illinois winter. My friends at the local Chevy dealer gave me a new 350 engine under warranty) paid to work for GM back then. The was one hot Caprice Broughm after that.
Clem;
