68 wireing ground points - NCRS Discussion Boards
  • Russ S.
    • April 30, 1982
    • 2161
    I have put in a new interior including dash so I have had entire dash removed. The car is back together but the courtesy lights will intermitently stay on until I slam the door a couple of times and then they will go out. I have made sure the switches are well grounded in the door pillars and I have cleaned up the ground strap from the bird cage to the frame. Can anyone tell me where the rest of the ground points are? Thanks, Russ
  • William H.
    • January 11, 2010
    • 65
    Re: 68 wireing ground points
    It sounds to me more like you have a switch problem???
      In terms of interior courtesy lights, their ground path IS through the door jamb switches...
      My experience with intermittent operation is the owner/restorer didn't know the factory original switches were "self-learning", he/she failed to reset them to their factory original un-installed configuration when they were removed, and the switch contacts weren't properly cleaned of past surface oxide growth when they were out...
      • Russ S.
        • April 30, 1982
        • 2161
        Guys, The switches are new and I did adjust them so that they would self learn I do strongly believe that it isn't a switch problem. Thanks, Russ
