Whats This Wire For? - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    Hi,
    I am putting the wiring back in my 71 LT-1. On the cowl, in the wiring harness right below the wiper motor, is a black wire sticking out of the harness, that has been cut. There are 3 black wires in this location that I can see. 1 is the transmission switch, the other is the ground wire from the hood alarm and fan motor which goes to the ground terminal on the wiper. The other is about 16 ga, and is cut off. I traced it back to the fuse block, where it changes to a large pink wire, which feeds the ignition switch. The wiring diagram, does not show anything else in the area, fed by a black wire. Any ideas? Thanks, Mark
  • Roger O.
    • September 7, 2009
    • 209
    Re: Whats This Wire For?
    Maybe it has something to do with the addition of the TI harness ?
    The only other black wire in that area that comes to mind is one for the ammeter but it won't turn pink but it does come through the firewall close to the pink.
    • Timothy B.
      • April 30, 1983
      • 5177
      Mark, I bet that wire is for the transistorized ignition..
        Could also be the discrete ground wire that services the CEC emission relays that bolt to the metal L-bracket on the firewall just to the left of the wiper motor...
        • Mark A.
          • February 1, 1996
          • 299
          Thanks for all the tips guys. I will check out all those possibilities. Mark
