Need some hinge advise....1966 - NCRS Discussion Boards
  • Michael G.
    • January 1, 1997
    • 1251
    Re: Need some hinge advise....1966
    Originally posted by Rich Pasqualone (49858)
    Twards the rear of the car. if necessary you could put 1/16" shims under the center bolts and 1/8" shims under the rear bolts. That would bring the door in close to a 1/4"
    Rich
    Good evening all,
    Wanted to update door install as shimming process was used this past Friday. A shout out of thanks to Wayne Womble, Richard Pasqualone and Ken Nabors whose suggestion to shim the lower hinges at the rear equated to success....IT WORKED! Door aligned perfectly ( well at least in Corvette standards) with the front fender. Another trick to add to the resto files. Thanks guys.
    • Wayne W.
      • April 30, 1982
      • 3605
      I would try, another hinge, take the hinge off and bend the flange, or shim the hinge so that it closes farther and pulls the door in. That would mean adding shims to the rear most bolts.
      Originally posted by Michael Gill (28614)
      Good evening all,
      Wanted to update door install as shimming process was used this past Friday. A shout out of thanks to Richard Pasqualone and Ken Nabors whose suggestion to shim the lower hinges at the rear equated to success....IT WORKED! Door aligned perfectly ( well at least in Corvette standards) with the front fender. Another trick to add to the resto files. Thanks guys.
      Hey, I was first. Give credit where credit is due.
      • Michael G.
        • January 1, 1997
        • 1251
        #18
        Done! Sorry Wayne failed to include the "ole great one"! Love happy endings..........believe I'm tearing up.
        • Wayne W.
          • April 30, 1982
          • 3605
          #19
          Now ya call me old. Damn.
