Can anyone refer me to a small block water pump rebuilder? Thanks.
C2 Water Pump Rebuilder?
Re: C2 Water Pump Rebuilder?
Bill Mock is one. He advertises in the DRIVELINE.
A second one is Arthur Gould in New York. Google the name for contact info.
There is also another guy who also advertises in the DRIVELINE. Can't remember the name right now, but if you look through the DRIVELINE you will see it.
Larry- Top
Bill Mock is the best. I've dealt with him numerous times.Bill Mock is one. He advertises in the DRIVELINE.
Larry
-Dave- Top
A top notch water pump rebuilder is Automotive Friction Company, Inc., 20521 SE Hwy 212, Damascus, OR 97089. Their phone number is 503-855-3670 or 800-545-9088, fax 503-855-3672. If you call you will probably talk with Lisa. I'm fairly close to the Portland OR area so the turnaround for me is pretty fast. If I UPS a pump to them on Monday, I've sometimes gotten it back on Thursday and never longer than Friday. Prices are very reasonable as well. They've never failed me.
Randy C.- Top
Ronald,
It's as close as you local NAPA store. I have done this several times. I have marked the unit (to make sure I get the original back). You get pictures of the unit documenting it, a quick turnaround, and an affordable price. I have done it with water pumps and master cylinders for myself and customers.
Tim- Top
I second Automotive Friction Company.
My first attempt was with a reputable company. I installed the rebuilt pump and the alternator belt pulley would not align. I then sent the pump to Automotive Friction Company and they rebuilt it with the correct offset for the fan pulley. The belts aligned perfect.- Top
