Just wanted to check on this one. During my regional flight review it was mentioned that the headlight bucket switch on the bottom left edge of the dash cluster is suppose to be moved away from the AC duct to an second notch in the dash still on the left-hand side but closer to the steering column.
Took this as gospel and just went to the AIM to double-check the exact position of this proposed move of the switch. The only reference that I was able to find was UPC C60 E7 which shows moving both the vent cable and bucket switch. However, as you can see from the image attached the AIM sheet that shows this change has been CANCELED. So, question is - was the headlight bucket switch moved or not?
Kirk
Kirk
hope that helps.
