I've been reading thru the search on temp gages in both discussion & archives to find a test for my problem. I recently purchased a new temp sender with calibrated resistor from LIC for my 65 396 (NOM; had an aftermarket gauge installed). After finding the green wire on the firewall, I soldered the necessary connections and plugged the 2 prong connector into the gauge under the dash. The needle at that point was in the center at 210. When I turned the key on, the needle pegged way, way beyond the 260 range. I immediately cut the power. I disconnected the the wire from the sending unit but nothing changed. Do I have a direct short to ground or simply a bad gauge? Are there specific test procedures I can do to find the problem?
