I am rebuilding my 1957 corvette engine. I have ordered the lower and upper dipstick tubes and the dipstick. I was told on here that the lower dipstick is installed from the outside top of the hole. The small end enters the hole easily but the flared upper end of the lower dipstick seems to be a bit to large to easily slip down the hole. There appears to be a small lip about an inch or so down the hole. Should one drive the tube and upper flared end down into the hole until the flared end stops on the inside lip? What should I drive it with or is there some other technique? I assume the outer curved dipstick tube then is installed down the hole.
Comments welcome.
Ted von Kampen
Comments welcome.
Ted von Kampen
Comments welcome.
Ted von Kampen
Comments welcome.
Ted von Kampen
