Here is a strange electrical problem. In my 65 when I turn on the parking lights, the right interior turn signal indicator stays on solid and does not blink. When you then turn on the headlights, it goes off. This is strange because I have not changed one thing with any of the wiring with the car. It just started doing this on its own.
Turn singal dash light
Re: Turn singal dash light
Craig, I think Joe has you on the right track, check the bulbs and make sure there the same brightness. when there is a bad ground on park lamps voltage tends to feed back to the turn indicator.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
