Just installed new POA valve "update"-actually a compressor cycler, expansion valve, and dryer, and recharged with real R12 on my '67 factory L79. Before work I was only getting 60 degrees from outlet. Now I'm getting 46 degrees, maybe 44, depending on whose thermometer you use, on recirculate high fan mode.80 degrees low humidity outside air.Heater valve is working. Shop manual says should be 40 or 42 degrees, but should I be satisfied and worry about something else?
