Just returned from our local October Vettefest in Old Town (Florida). The registration line took so long that I saw about 195 degrees on my L-76 63 with all the idling. I have a new 180 thermostat in it and it has been performing fine. On the ride home on SR417 it ran well holding good oil pressure and right at 180 temp. Then my son and I had to manuver some to get to our exit (he has a 96 GS). I passed him and ran up to about 100 mph in order to get past some other cars, so when I made the exit and started to brake and down shift, between gears my son said I was blowing out a lot of blue/black smoke. When I got to the stop light, the temp was pegged at 245 and it was pucking out antifreeze out of the overflow bigtime - so much that my wheels spun trying to start out again. I nursed it home (about 2 miles), and it continued to puck coolant.
Preliminary check of things showed;
- no broken or split hoses,
- nothing out the side of the block,
- oil looks at right level with no sign of coolant
- coolant tank is all pucked out/empty.
Engine started up as if still hot, i.e. had to crank and give it more gas, but it seemed to run ok with normal idle speed and no unusual noises, so I moved it into the garage.
My thoughts/hopes are that perhaps the thermostat stuck open and it just plain overheated, specially under the stress of high rpm's.
Any thoughts?
Stu Fox
Any thoughts?
Stu Fox
