Well it's down to the last pieces to prep for paint.
Going through the judging guide I see the door striker pin washers are phosphate black but no comment on the pin/bolts themselves.
From looking at the original there is also some confusion because some dealers sell a cadmium plated door striker pin with the first washer in cadmium, not black.
And of the striker pins I've seen, none seem to have the rubber band I have remaining on the left pin (the right pin seems to have washer of sorts between the rotating collar and the pin top!?!).
So, for a 77
1. is the striker pin itself left as cadmium plated.
2. is the top washer left as cadmuim plated
3. is there normally a rubber band below the rotating collar.
4. is that actually a rubber washer above the rotating collar.
For bonus points, I've noticed a flat spot ot the side of the pin top. Is this meant to be a locater of some sort ???
Thanks all for your input.
Michael B.
So, for a 77
Michael B.
