Original BR 270 Delco Remy Coils - NCRS Discussion Boards
  • Joe M.
    • February 18, 2010
    • 83
    Does anyone know if the (very small) number under the negative side of the coil is a date code? I have two BR 270 coils and under one terminal it reads 16 and under the other coil its 265. I just want to make sure I use the correct one for judging.
    • 6940
    Re: Original BR 270 Delco Remy Coils
    Joe my 72 L-48 has a BR 270 coil, not sure about the other numbers though. I believe that that is the only number judged other that the word Delco remey and its font.
    • Wayne M.
      • March 1, 1980
      • 6414
      Joe -- about 20 years ago, I got the 270-BR coil and the 1112247 4E31 distributor off a '74. Believe the coil is original (although I know zip about TFP coils on C3's).
      Pic shows nothing around negative post, and "BS" around the +ve; don't know whether that's a code or a statement .
      • William C.
        • May 31, 1975
        • 6037
        More likely a cavity number to trace a mold problem if (when) one was found.
        Bill Clupper #618
