Gas cap for a '62 - NCRS Discussion Boards
Gas cap for a '62
  • David H.
    • November 11, 2009
    • 777
    Gas cap for a '62
    I remember the discussion recently about stolen gas caps and their value.
    I find a gas cap available on ebay listed for the '62 with this description,
    "new g40 correct logo gas cap from the original gm supplier. stant made the cap for gm says anti-surge vented on top and has the small stamped sms on one wing"
    Is this a correct gas cap for the '62. No gm part number is listed.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Gas cap for a '62
    David,
    Three different caps were used in 62.
    One by Emerson Fuller which has an F and an E stamped on the top.
    the next was an Eaton cap which has sort of an embossed stylized "X" on the top. The third was by Standt.
    I can't enlarge your picture so I don't know if your Standt cap is correct.
    All are zinc plated and pictured in the JM..
    Info is from an old NCRS judging manual dated fall of 1992.
    • Donald L.
      • September 30, 1998
      • 461
      I believe the only correct cap for the 62 MY is the Fuller & Emerson cap. The General used F&E caps exclusvly for gas caps on or about 3/61. There is a repro for the F&E cap ($250)
      • David H.
        • November 11, 2009
        • 777
        What a great education I am getting from all this.
        My cap is the Emerson & Fuller cap as it has the E F embosed on it.
        The caps on ebay are Stant caps.
        Here is the entire description and another try at the picture.
        1953-62 nos Chevrolet corvette gas cap
        ______________________________________________
        new g40 correct logo gas cap from the original gm supplier. stant made the cap for gm says anti-surge vented on top and has the small stamped sms on one wing.
        these caps are very old and plating has some small areas where it has begun to deteriorate so not perfect
        fits all 1953,1954,1955,1956,1957,1958,1959,1960,1961,1962 Chevrolet corvette.
        Item number is 140450211302 for those interested.
        I will use my original now that I know it is just that.
        Thanks very much for the info.
        dlh
          David -
          Aside from the other issues, clue #1 that the cap in the auction is incorrect is that it has "vented" embossed on it; all mid-'57 through 1962 gas caps were non-vented (the tank was vented separately into the filler cavity).
