I am going to pull my heads to have them ported and install the correct shim type gasket. All the talk about connecting rods has me thinking of going further and replacing the rods as an insurance measure.
I called Eagle and they recommended their H beam rods for an engine that might see 7000rpm. If I buy these I will have to convert the pistons to floating pins. I could also go to a 6.125" rod with a 350 piston designed for a 6" rod and improve the rod/stroke ratio which would improve the top end. If I do this I will have to take the whole engine apart. At a minimium I think I would have to rebalance the crankshaft(???)
The engine seems to be in great shape but I don't know how many miles are on it or what was done to the rods when it was apart. I am not particularly anxious to spend a lot of money for nothing.
I have read the various posts on the subject. The question is whether it is worth taking the engine apart just to change to rods. I do reach 6500 rpm on the tach now and then and I am not sure of the accuracy of the tach. With the heads pocket ported, it seems the engine will be much more willing to reach high rpm and it will be hard not to indulge.
So I have a few questions
Should I get the H beam type rods (which are only availible with floating pins?
If I get the H beam rods, is there enough benefit to go to the longer rods?
How much risk of a rod failure is there using the stock redline on the stock tach?
Should I just leave the bottom end alone for now?
