1967 center console - NCRS Discussion Boards
1967 center console
  • John M.
    • June 27, 2010
    • 179
    1967 center console
  • Scott S.
    • September 11, 2009
    • 1961
    Re: 1967 center console
    Hi John,
    Are you referring to the center section containing the rubber shift-boot and the ash tray door?
    • John M.
      • June 27, 2010
      • 179
      yes, removed all the back rivets but that section is stuck
      • Scott S.
        • 1961
        If you check the picture I posted, near the top of the picture, you will see a toothpick inserted between the brushed aluminum overlay and the shifter console underneath. I have not removed mine completely yet, just pried up the edges to see how it was attached. It is glued on, and should peel off like a sheet of aluminum. If I understand correctly, nothing else "comes out" besides the ash tray door - that whole center section encompassing the rubber shift-boot and ash tray door is a permanent, fixed part of the larger console.
        If possible, save the shift-pattern indicator plate. If it's a 4-speed, my understanding is that the reproductions are not quite exactly the same, and the NOS replacements are the 1963 style, which were then used for SERVICE on 1964-1967. They have tabs on the sides (designed for the unique 1963 shifter center console) and are not the same as the PRODUCTION shift-pattern indicator plate used from 1964-1967.
          John -
          The entire console is a one-piece die-casting - nothing "comes out". The brushed aluminum plate around the shifter opening and ashtray is a separate decorative part, glued to the base casting.
