My pedal was going all the way to floor with "brake " light on dash going on. Master cylinder was full.Mechanic bled brakes, said had air and fluid was dirty but saw no leaks. I THINK? this temorarily made pedal firm or at least firmer but problem has returned. A knowledgeable friend says if bleeding temporarily cured problem, must be a small leak on one of the calipers instead of bypassing master cylinder. How can I tell for sure which is problem? Best way to detect a subtle leaking caliper?
Thanks in advance,
Bill Ford
Thanks in advance,
Bill Ford
