Warning: Undefined array key 0 in .../vb/user.php on line 530 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530 Warning: Undefined array key 0 in .../vb/usercontext.php on line 221 Warning: Trying to access array offset on value of type null in .../vb/usercontext.php on line 221 Warning: Undefined array key 0 in .../vb/user.php on line 530 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530 63 windshield washer - NCRS Discussion Boards
  • John S.
    • May 17, 2009
    • 164
    I have my 63 windshield washer working to spray water, but when running is pretty loud with clunking/clicking sound. What is acceptable noise level?
    Any 'fix' for this?
  • John K.
    Infrequent User
    • December 4, 2009
    • 18
    Re: 63 windshield washer
    Hi John
    Last week I rebuilt the washer pump on my 63. When I first tried to run the pump it had many noises . I took it apart again an noticed that the roller which rides on the actuator cam was not turning. A little pb blaster and some coaxing got the cam follower roller to function as it should. I also think I didn't have the cam drive pin in the cam slot. I was very careful in the re assembly of the pump making sure every thing lined up as it should and it works like a charm. I rebuilt my pump without removing the wiper motor from the car. I also found that when I took the distributor cap off removing and replacing the pup bolts was a breeze.
