Opinion on this C3 - NCRS Discussion Boards
Opinion on this C3
  • Glen C.
    • July 15, 2009
    • 216
    Opinion on this C3
    Can anyone give me their opinion on the value of this 1972. The price seems to fall within my price range but I'm still feeling my way around the C3's.
    Glen
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Opinion on this C3
    It's hard t say without a personal inspection, but from the ad, the car doesn't sound like a bad buy. You don't get much of a bumper C3 for that kind of money.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Glen C.
      • July 15, 2009
      • 216
      Thanks Tom. Do you happent to know how difficult is it to get the original a/c compressor rebuilt?
      • Paul J.
        • September 9, 2008
        • 2091
        Glen,
        That's a reasonable price for what the car is. It might be a little high, but the owner has done some work to it recently and not too many things are missing. It would make a great driver.
        Anyone can rebuild the compressor, but you may wish to convert it to R134a if you're going to drive the car much. A complete system repair can run between $800 and $1800 depending on what you want to do with the system. If you want to stay with R-12, check out some of the vendors in Driveline or google vintage AC repair and restoration. That should give you a better idea of the cost.
        Paul
        • Roy V.
          • April 8, 2008
          • 296
          he started out at 13,500 on the other forum and is now at 12,500. to me it sounds like a good deal in todays market.
          http://forums.corvetteforum.com/c3s-...uildsheet.html
          Regards
          Roy
          • Tom H.
            • December 1, 1993
            • 3440
            I agree with Paul !
            Tom Hendricks
              • 11608
              Not a bad car depending on yoru goals.
              The frame at one of the trailing arms looks a bit suspicious, so I'd check that area out thorougly.
              You could probably drive it and then work on it over time to bring it back to stock, if that was what you wanted.
              Patrick
                Patrick
                Patrick-------
                Yes, I noticed that, too. Plus, the car lives in Ohio which, by itself, would be cause for concern. I would say if the frame checks out solid, it would be a good buy even if the car has other problems that are not readily apparent. However, if the frame is bad, I wouldn't touch it at any price.
                • Gerard R.
                  • November 1, 1993
                  • 61
                  Regards
                  Roy
                  I agree that is a great price.
                    Gerard------
                    It is but as I mentioned IF AND ONLY IF THE CAR HAS NO SIGNIFICANT FRAME OR BIRDCAGE CORROSION. If it does, I would not touch it at ANY price.
                    • Thomas H.
                      • August 31, 2005
                      • 1053
                      Gerard------
                      I second Joe's comment. Glen, if you are interested, I would try to locate someone in Ohio that can go inspect it for you. That is what I did when I bought my C3 (I'm in Pa and the car was in MI) and it was money well spent.
                      It looks like a real nice driver at a very fair price. Good luck!
                      Tom
                      2007 Z06, Lemans Blue
