I need to replace the tires on my '64 soon. The existing tires are bias ply but of a non-OEM brand and have the DOT verbage. One also has a cut in the sdiewall.
So I'm reading the 1964 JG to get some direction on what to replace them with. The JG indicates the 5 brands and models of Rayon bias ply tires that were originally available on the car. It also lists 2 brands with models of "Optional" Nylon bias ply tires that were available at that time.
Under "Reproduction Tires" it mentions bias ply in the correct size for the car (6.70-15).
Under "Service Reeplacement Tires" is describes bias and radial construction tires.
What it doesn't tell me is what points are deducted in each case. I imagine having bias ply tires with one of the 5 brands and madela in the correct size and in good condition and meeting all of the other mentioned criteria would receive full points. Since I don't think these are available or if available they would be extreemly expensive and probably unsafe, I am disregarding them.
I'm picking up on the fact that to get some points the tires on the car must be one of the 5 named brands. Now for my questions:
-If I have one of the 5 brands must they also be the named model of that brand (if those models are even available today)?
-Coker Tire advertises bias ply tires in several of the original brands but doesn't mention the model. What sort of point hit would one receive if the car has reproduction bias ply tires in a correct brand but incorrect model, presumnably also having DOT labels?
-Since "Service Replacement" tires are mentioned and radials are included in this category, what sort of points hit will I receive if I have a correct brand in a correct conversion size but in a radial ply tire?
I'd really rather put radials on the car for both safety, ride and handling, but I would also like to know what that choice would do to me in judging verses bias ply reproductions.
I'm certain others ahve been through this decision making process but I have not found such info in the TDB threads. Any help/opinions/advice will be appreciated.
Thanks-Doug
Thanks-Doug
