I'm trying to take the front suspension apart on my 1960 project. I am using the excellent document that Tom Parsons provided. I am to the point of taking the lower A-frame outer shaft/bolt out. I was looking at Tom's notes, the ST-12 and the AIM. What I have discovered is that someone in the past seems to have put the outer shaft/bolt in backwards. I have a picture attached that shows the end of the bolt with the grease fitting on the front side of the A-frame. The ST-12 doesn't have a good picture but references taking the fitting and bolt out the back side. All of the pictures from Tom's notes show retaining nut on the front side of the A-frame and the grease fitting on the back side.
Can I just proceed to unscrew the shaft/bolt from the front side? I can't seem to get it to budge and don't want to damage anything. Assuming I am right and it is in backwards, has it done any harm to the A-frame or Spindle? I may not have been drive this way, as the car has been sitting for 5-7 years during a restoration.
Don
Don
