In the process of having the original, correct date A6 compressor rebuilt, I need to figure out what to do about the paint, the yellow "O.K. Final Test" stamp and the foil label. I am guessing that the foil label can be carefully removed and saved as a reference, to be replaced with a reproduction, and use a typewriter to hammer out the correct date code (matching the original) into the foil.
About the paint: the rebuilder says he usually bead-blasts the exterior clean and repaints. The 1967 JG says the compressor should be semi-gloss black (p. 91).
Unfortunately, bead-blasting and repainting will obliterate the original yellow "O.K. Final Test - CHEV." inspection stamp.
Questions:
1. What kind of semi-gloss black paint is recommended for this under-hood application?
2. Should an attempt be made to mask-off the original yellow inspection stamp to preserve it, or is this the kind of thing that is normally media-blasted/painted over and then re-stamped? I don't know if this is something that should normally be preserved (I'd rather not find out too late), or whether this is something that is normally painted over and re-stamped with the "O.K. Final Test - CHEV." symbol.
3. Are there any other cosmetic issues to be aware of?
Questions:
