I've restored my engine and had my Powerglide transmission rebuilt. Everything works great, except the Powerglide downshifts are bone-jarringly hard. The trans guy says the vacuum source for the modulator should be manifold (intake) vacuum, NOT ported vacuum. Other web sites on Powerglides appear to confirm this.
The 1963 assembly manual (M35, sheet 4) shows the modulator line having a "T" on the engine end, which is connected to the distributor vacuum advance, with the straight end of the modulator line being connected to the front of the Carter AFB carburetor. This is exactly how I have the modulator, distributor advance and carburetor lines connected.
Questions: Assuming the distributor vacuum advance wants ported vacuum, and the Powerglide modulator wants manifold vacuum, how can both be connected to the same line, as shown in the 63 Assembly Manual?
Is the front port on the Carter AFB ported vacuum or manifold? My guess is ported, since it is connected to the Distributor vacuum advance. but I can check this easy enough with my vacuum gauge tonight.
Is it possible that either the Corvette Powerglide modulator and/or the Corvette distributor vacuum advance, are different? Could it be that the Corvette Powerglide modulator works off ported vacuum or the Corvette distributor vacuum advance works off manifold vacuum?
Any other theories on how the trans guy and the assembly manual can both be right, or advice on which is wrong?
Thank you!
Doug
Thank you!
Doug
