I lost 2 points at Regionals because of the "wrinkle" in the soft top matieral. You can see it right behind the wireon area. In other words, from the bottom of the soft top near the back, follow the seam straight up alongside the window until it hits the piece that runs side-to-side across the back. At the JUNCTION of those two, the main part of the vinyl is wrinkled a bit. The wrinkle shows as a slight shadow in this picture.
I looked at an article I had on how the shop would have installed the top. It looks like the rear wireon piece is STAPLED onto the top. If that's the case, how the heck can I fix this?
