C1 Rear Leaf Springs - Are these OK? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    I have attached two photos of the right side leaf springs. Not how the front of the springs as they reach the shackle start to recurve. Is this correct? Both sides look the same. The picture is with the frame support by a floor jack under the differential, so frame weight is on the springs. But it doesn't see to change much with the weight off.
    Do I need to get these re-arched?
    Don Harris
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Jerry C.
    • November 1, 1995
    • 741
    Re: C1 Rear Leaf Springs - Are these OK?
    Photo's did not show up.
    • Donald H.
      • November 2, 2009
      • 2580
      Woops. I forgot to attach photos. Have edited the original post and attached photos now.
      Don
      Don Harris
      • Mike M.
        • May 31, 1974
        • 8365
        both photos show extreme distortion of the springs,probably due to severe wheelhop in the past. mike
        • Don H.
          • December 1, 1981
          • 1482
          As usual Mike is correct. Very common for solid axle leaf spring. My limited experience is they will bend back if stressed (IE: hard acceleration). Don H.
          • Tom P.
            • April 1, 1980
            • 1814
            Looks to me like a severe application of torque-----------------as in drag racing!
            NO, that is NOT correct. If they were mine, I would NOT replace them, I'd have them correctly rearched and put them back on.
            • Donald H.
              • November 2, 2009
              • 2580
              OK, so who does the rearch of leaf springs?
              Don Harris
              • Terry D.
                • May 31, 1987
                • 2690
                Try Eaton Spring in Michigan, should be several articles in the archives
