It looks like there is no way to fitt the expansion tank into the spot where it is supposed to go on my 327 air car, were there diffenent sized expansion tanks for air cars?, got mine from c central it seems to be the only one offered , the original tank was missing, but the bracket is in place any suggestions?
66 sb /w air , expansion tank fit
Tags: None
- Top
Re: 66 sb /w air , expansion tank fit
If your inner fender panel is a replacement, the tank bracket may have been installed too low. I had that problem and solved the slight interference problem by putting a relief dent in the tank.
Relocating the bracket is the cleaner option, but I was not in the mood at that point.
- Top
thank you for the help guys, we'll make it right, now that I know I have the right parts, GRR- Top
