UA6 alarm system 1969 corvette - NCRS Discussion Boards
  • Matthew L.
    • August 29, 2010
    • 187
    What does the UA6 alarm system in the 1969 corvettes consist of???
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: UA6 alarm system 1969 corvette
    You have the key/lock on the rear valence to activate it.
    You have the relay and flasher UNDER the flocked cardboard box on the passengers side, where the jack is stored.
    You have a plunger switch (SW Logo) under the hood....passenger side....firewall area.
    You have the alarm wired into the courtesy light plunger switches in both doors.
    You have a trumpeted horn mounted behind the drivers rear wheel fender well.
    With the alarm "set", if either door or the hood is opened, the alarm goes off.
    If you look in the AIM, there are several pages of diagrams for this option.
    Chuck
