Radiator Hose Questions - NCRS Discussion Boards
  • Patrick N.
    • March 10, 2008
    • 951
    I am ready to replace my upper and lower radiator hoses and see that 68 has an early and late design for radiator hoses, what are the differences? Also-i notice different markings/PN's on the hoses offered by different vendors.
    What type / markings should I be looking for on my march car,
    Thanks again!
    Pat
    Re: Radiator Hose Questions
    Thanks again!
    Pat
    Pat-----
    It only affects the upper hose, not the lower. My recollection is that the second design was slightly longer than the first with a very slight difference in the curvature. I don't think you could tell the difference on the car if it were not for the different part numbers---that's the primary visual difference. However, I don't think the first design hose is reproduced, and, if so, that doesn't leave you many options but to use the second design.
    • Patrick N.
      • March 10, 2008
      • 951
      Thanks Joe! as always.
      Pat
